да кстати у меня есть Hiren's Boot CD - рульная весчь - юзаю оч нравится
тоже
оч советуюHiren's Boot CDPartition Tools
Partition Magic 8.2
Best software to partition hard drive
Paragon Partition Manager 5.5
Universal tool for partitions
Partition Commander 8.01
The safe way to partition your hard drive,with undo feature
Ranish Partition Manager 2.44
a boot manager and hard disk partitioner.
The Partition Resizer v1.3.4
move and resize your partitions in one step and more.
Smart Fdisk 2.05
a simple harddisk partition manager
SPecial Fdisk
SPFDISK a partition tool.
eXtended Fdisk
XFDISK allows easy partition creation and edition
Disk Clone Tools
Drive Image 2002
Best software to clone hard drive
Norton Ghost 8.0
Similar to Drive Image
Partition Saver 2.80
A tool to backup/restore partitions.
Antivirus Tools
F-Prot Antivirus 3.14e
Very good virus scanner (with ntfs support and easy to use menu)
McAfee Antivirus 4.32
a virus scanner (with ntfs support and easy to use menu)
Recovery Tools
Offline NT/2K/XP Password Changer
utility to reset windows nt/2000/xp administrator/user password.
Active Partition Recovery 2.1
To Recover a Deleted partition.
Active Uneraser 2.1.1
To recover deleted files and folders on FAT and NTFS systems.
Ontrack Easy Recovery Pro 6.3
To Recover data that has been deleted/virus attack
Winternals Disk Commander 1.1
more than just a standard deleted-file recovery utility
TestDisk 4.5.
Tool to check and undelete partition.
Lost & Found 1.06
a good old data recovery software.
Testing Tools
DocMemory 2.0
RAM Test utility
GoldMemory 5.07
RAM Test utility
Memtest 2.00
PC Memory Test
System Speed Test 4.78
it tests CPU, harddrive, ect.
PC-Check 5.50
Easy to use hardware tests
The Troubleshooter 5.02
all kind of hardware testing tool
PC Doctor 3.0
a benchmarking and information tool
Test Cpu/Video/Disk 5.6
a tool to test cpu, video, and disk
Hard Disk Tools
Hard Disk Diagnostic Utilities
Seagate Seatools Desktop Edition 2.10
Western Digital Data Lifeguard Tools
Maxtor PowerMax 4.6
Fujitsu HDD Diagnostic Tool 6.10
Samsung HDD Utility 1.11
IBM/Hitachi Drive Fitness Test
MHDD 2.9
HDD Regenerator 1.41
to recover a bad hard drive
Ontrack Disk Manager 9.57
Disk Test/Format/Maintenance tool.
Norton Disk Doctor 2002
a tool to repair a damaged disk, or to diagnose your hard drive.
Norton Disk Editor 2002
a powerful disk editing, manual data recovery tool.
Active Kill Disk 1.1
Securely overwrites and destroys all data on physical drive.
SmartUDM 2.00
Hard Disk Drive S.M.A.R.T. Viewer.
System Information Tools
Aida16 2.12
a system information tool, extracts details of all components of the PC
PCI and AGP info Tool
The PCI System information & Exploration tool.
System Analyser version 5.3b
View extensive information about your hardware
NavrАtil Software System Information 0.58
High-end professional system information tool
Astra 4.20
Advanced System info Tool and Reporting Assistant
HwInfo 4.93
a powerful system information utility
PC-Config 9.33
Complete hardware detection of your computer
SysChk 2.46
Find out exactly what is under the hood of your PC
Dos File Managers
Volkov Commander 4.99
Dos File Manager with LongFileName/ntfs support (Similar to Norton Commander)
Dos Command Center 5.1
Classic dos-based file manager.
File Wizard 1.35
a file manager - colored files, drag and drop copy, move, delete etc.
File Maven 3.5
an advanced Dos file manager with high speed PC-to-PC file
transfers via serial or parallel cable
FastLynx 2.0
Dos file manager with Pc to Pc file transfer capability
LapLink 5.0
the smart way to transfer files and directories between PCs.
Mini Windows 3.11
Back to old days, use it as a file manager
Other Tools
DosCDroast beta 2
Dos CD Burning Tools
Ontrack Data Advisor 5.0
Powerful diagnostic tool for assessing the condition of your computer
Bootmagic 8.0
This tool is for multi boot operating systems
Picture Viewer 1.94
Picture viewer for dos, supports more then 40 filetypes.
QuickView Pro 2.51
movie viewer for dos, supports many format including divx.
Universal TCP/IP Network 4.80
MSDOS Network Client to connect via TCP/IP to a Microsoft based network. The network can either be a peer-to-peer or a server based network, it contains 67 different network card drivers
NTFS Dos Pro 5.0
To access ntfs partitions from Dos
Dos Tools
NTFS Dos Pro 5.0
USB CD-Rom Driver 1
Standard usb_cd.sys driver for cd drive
Universal USB Driver 2
Panasonic v2.06 ASPI Manager for USB mass storage
Interlnk support at COM1
To access another computer from COM port
Interlnk support at LPT1
To access another computer from LPT port
and too many great dos tools
very good collection of dos utilities extract.exe pkzip.exe pkunzip.exe unrar.exe rar.exe ace.exe lha.exe gzip.exe scandisk.exe scanreg.exe attrib.com deltree.exe xxcopy.exe diskcopy.com dskimage.exe undelete.com edit.com editbini.exe fdisk.exefdisk2.exe freefdsk.exe lf.exekilldisk.exe delpart.exe wipe.com zap.com format.com mhdd.exe find.exe sort.exe move.exe more.com hex.exe debug.exe regedit.exe split.exe label.exe mem.exe mi.com mhdd.exe xmsdsk.exe doskey.exe duse.exe sys.com mbrwork.exe bootpart.exe bootsave.exe bootrest.exe bootfix.com sbminst.exe cmos.com cmospwc.exe cmospwd.exe ibios.exe biosdtct.exe killcmos.com cpuid.exe smartdrv.exe loadlin.exe guest.exe intersvr.exe interlnk.exe mouse.com lfndos.exe doslfn.com
Windows Tools
SpaceMonger 1.4
keeping track of the free space on your computer
Drive Temperature 1.0
Hard Disk Drive temperature meter
Disk Speed1.0
Hard Disk Drive Speed Testing Tool
MemTest 1.0
a Memory Testing Tool
PageDfrg 2.21
System file Defragmenter For NT/2k/XP
Split Join 1.3.3
a Small File Split-Join Tool
Ghost Image Explorer 7.0
to add/remove/extract files from Ghost image file
DriveImage Explorer 5.0
to add/remove/extract files from Drive image file
Active File Recovery 2.0
a tool to recover deleted files
Restoration 2.5.14
Startup Control Panel 2.8
a tool to edit startup programs
TCPView 2.34
a detailed listings of all TCP and UDP endpoints
Unknown Devices 1.2
helps you find what those unknown devices in Device Manager really are
Ad-Aware 6.181
find and remove spyware, adware, dialers etc. (a must have tool)
как скачать
1.
http://www.google.com/search?q=Hiren's+BootCD2.
http://boot.vabank.net/index.php?option=co...ad&filecatid=143.
http://download.fluxxnet.com/applications/...irenbootcd6.zip4.
http://www.rusc.ru/files/Hirens.BootCD.6.0.zip5.
http://www.uucyc.com/archives/Hiren's%20BootCD.6.0.zip 6.
http://www.rusc.ru/files/Hirens.BootCD.6.0.zip7.
http://www.corpax.com/damian/hirenbootcd6.zip8.
http://www.dontek.ru/soft/get_from_dontekH....BootCD.6.0.zip
